posi unit advise needed
Old Mar 30, 2014 | 01:07 PM
85raideROC's Avatar
Car: 1985 iroc-z28
Engine: 305 t.p.i
hello.im looking to upgrade my gears and hope to get some advise.i drive a 85 irocz28.305 tpi 700r4.all stock.i currently been offered a complete rearend froma 95 z28.its a posi with 3.42 gears and disc brakes.i currently have the 3.23 non posi disc rearend and wanted to know if only the posi unit itself from the 95 will fit into my differential housing? because i hear the complete rearend will be slighty longer than the stock one.any answers are appreciated.thanks!
Old Mar 30, 2014 | 01:16 PM
big gear head's Avatar
Re: posi unit advise needed
No, it wont work. Your '85 has 26 spline axles and the '95 has 28 spline axles. The differential in the '95 will be an Auburn. You can upgrade yours by using a set of '90 to '92 axles, but I wouldn't bother installing a use Auburn. A new Eaton Posi, Yukon Dura Grip or a Eaton Truetrac would be good. If you do the 28 spline upgrade the a used Torsen from a '98 to '02 would be good.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
mcgarnicle
Aug 12, 2015 04:58 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
