84 camaro rear axle assy fit a 92 camaro?
Car: 92 camaro rs
Engine: 305 t.b.i.
Hi everyone.
I currently have a 92 camaro rs with a bad rear (growls around 30+ mph and stops when let off gas) a friend has an 84 camaro with 3.08 gears and he will sell me the complete rear out of it for $75
my question is with this rear fit my 92 or will I need to do major modifications? both have drum brakes.
thanks
mark
thanks
mark
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 84 camaro rear axle assy fit a 92 camaro?
Should be exactly the same however you'll be downgrading from 28 spline to 26 spline axles.
Your RS will have 2.73 gears so swapping the diff to the 3.08 gears means your speedometer will be off.
Car: 92 camaro rs
Engine: 305 t.b.i.
Thanks, that's what I was afraid of too making my speedometer off. So I guess no mater what gear ratio I increase to my speedometer will be off. Is there a way to correct it?
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
you just need the right gear for the speedometer.its really easy to change. bought mine at the chevy dealer.i don't know if they are still available.maybe your friend could include the gear since he doesn't need it anymore.SAVE the axles from the 92 rearend.you can swap in a 4th gen posi with them.
sailtexas186548
Jan 19, 2016 12:21 PM
