Detailed T56 swap
Old Apr 10, 2014 | 06:29 PM
nizzlemanu's Avatar
Car: 91 TA GTA
Transmission: 700 R4 massive slip edition
Detailed T56 swap
Well my 700 is down to two gears so I figured now would be a good time to do a transmission swap (on a side note I had just changed the tranny fluid before it went out). I've decided on installing a T56 even though everyone says it will pair poorly with the stock 305 tpi that I have. I don't really care because I need to put in a new transmission and I want a manual. Anyways because the car is my DD I plan on doing the pedal swap first then having everything ready to go so I can install the transmission in a weekend or so. I've never done anything with transmissions before so this would probably be a good thread for a beginner such as myself to learn from all of my mistakes. Also I am going to post every single thing that I have to buy for the swap to get an accurate cost.
Well here is what I have ordered so far and plan on installing on the weekend. I wanted to do this with the least amount of hassle possible so I am ordering a lot of new parts instead of trolling junk yards.
4th gen pedals
- ebay $150
pre-bled master slave assembly
-gmpartsdirect # 12559912 $130
clutch pedal retainer
-gmpartsdirect # 3817880 $1.50
clutch pedal bushing
-gmpartsdirect # 14091384 $5.54
firewall u bolt
-gmpartsdirect # 14076942 $2.93
Here goes nothing
Old Apr 10, 2014 | 06:37 PM
bvahnee's Avatar
Re: Detailed T56 swap
I did this a couple years ago so its still fresh in my mind, any questions PM me and Ill do my best to help you out. Good luck!
Old Apr 11, 2014 | 01:09 AM
nizzlemanu's Avatar
Car: 91 TA GTA
Thanks, even though I feel like I've spent a solid month researching I will probably still need some help.
Old Apr 11, 2014 | 12:00 PM
Pocket's Avatar
Car: 91 Trans Am
Why would it pair poorly with the 305TPI?
Id suggest a gear change because the stock 2.73's will gut the bottom end torque
Old Apr 11, 2014 | 08:56 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
most v6 cars have 3.42 rearends and its a direct swap.
AussiePr0nCar
Mar 6, 2020 04:04 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
19irocz85
Aug 26, 2015 07:54 PM
jharrison5
Aug 19, 2015 05:53 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
