168 tooth flex plate
Old Apr 14, 2014 | 01:04 PM
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Will my 87 torque converter bolt up to a 168 tooth flexplate?Will the 168 tooth flex plate clear my auto trans?THANKS
Old Apr 14, 2014 | 05:54 PM
Re: 168 tooth flex plate
Yes (almost) and yes.
The "almost" is, it depends on the motor in your car. If it's 86-up, all you need is one from something common and everyday like a TBI (87-95) truck. If it's 85-back, you need an equally common and everyday item, except that the converter bolt pattern will be in SAE units, where the 700 bolt pattern is metric. The difference is that the bolt holes may need to be elongated slightly. (emphasis on "slightly") They're a slightly different distance from the crank compared to a 350/400, can't remember which way though. I think the 700 converter pattern is slightly larger but I could easily be wrong about that. whichever way it is, the difference is less than 1/8".
Old Apr 14, 2014 | 07:49 PM
Steve Mack's Avatar
Car: 87 Iroc
Thanks for the info .I hope I can get it to fit.
Old Apr 14, 2014 | 07:52 PM
Steve Mack's Avatar
Car: 87 Iroc
delete
loud91rs
Oct 5, 2015 10:05 PM
gord327
Oct 3, 2015 01:25 PM
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
