Another lockup question
Old Apr 15, 2014 | 09:42 AM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
So, my lockup circuit is acting stupid on my 91 1le. At steady cruise in 4th the converter locks and unlocks every 5-10 seconds. I was going to temporarily wire up a switch to manualy command the lock up on to verify if ive got a solenoid that failing or a control issue from the pcm. What Im thinking of doing instead is installing this tci manual converter control kit along with replacement lockup solenoid. http://www.summitracing.com/parts/tci-376600/overview/
There shouldnt be any issues running this on an otherwise stock pcm setup do you think?
Old Apr 15, 2014 | 05:59 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Another lockup question
May also want to check the TCC switch on the brake pedal.
If it is flaky you may have intermittent power into the TCC circuit
What Im thinking of doing instead is installing this tci manual converter control kit along with replacement lockup solenoid.?
If you are going drop the pan to install the solenoid ,why not just install a switch in the 4th gear port of the valve body and do a little int rewiring ?
Trans will lock only and always when it is in 4th , disengage when the brake used and no need for any ext control
Old Apr 15, 2014 | 08:31 PM
Car: 1991 Z28 1LE
Transmission: 4l60e
Any source for more info on this mod?
Old Apr 15, 2014 | 10:16 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Some enlightenment
https://www.thirdgen.org/forums/tran...cc-lockup.html
https://www.thirdgen.org/forums/carb...c-control.html
Old Apr 16, 2014 | 08:34 AM
Car: 1991 Z28 1LE
Transmission: 4l60e
thank you, I have been off the site for a while my searching skills are lacking...
Bubbajones_ya
Aug 31, 2015 12:02 PM
someone972
Aug 30, 2015 12:52 AM
Eric-86sc
Aug 24, 2015 09:01 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
