T5 speedometer housings
Car: '87 Camaro
Are there different t5 speedometer housings because my mechanical vss pulse sender doesn't fit. When i try to put the sender in the threads don't reach the housing threads.
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
Re: T5 speedometer housings
Take a peek at the T-5 sticky.. Can't directly answer your question but you might find it in the sticky above..
Good luck
Chuck
Good luck
Chuck
