do i need a new trans?
Old Apr 25, 2014 | 05:47 PM
dixie wrecked's Avatar
Car: 91 ws6
Engine: Carb'd 334 stroker
Hello, I have an 85 t/a, automatic.
Finally got to testing the trans..on her maiden voyage I discovered it won't shift from first. I have reverse, park, neutral and first. First runs STRONG.
I was told by a previous owner that his kid couldn't keep his foot out of it and fragged two tranny's, this was a newer one.
Car has 36k original miles.
I pulled the trans pan, fluid was nice and didn't smell burned, tho there was a smallish amount of black media in the bottom. Nothing on the magnet.
The governer gear wasn't stripped..but didn't move at all, in any direction. 3 of the pistons on the valve body were seized, as in wouldn't move even with a hammer and chisel. Gear 1 was open and wouldn't close, the spring was broken, and what looks like a guide part of the valve body over the open piston was broken off, and what looks like a pump (bottom of the VB, pass side with 3 bolts. Inside the cap was a spring, the other side went to the plate above the valve body) had a broken spring.
I'm new-ish to transmissions, so I'm not sure if repairing/replacing the broken parts would fix the problem, of if I'm better off getting another used transmission. On a **** broke budget..so spending outrageous monies for a high end trans isn't an option.
Old Apr 25, 2014 | 07:21 PM
Car: 91 ws6
Also while on her maiden voyage the other day, the TV cable came unhooked, I drove it for like 3 miles unknowingly like that. My TV cable bracket was busted, and I converted to carb, so I had to cut the cable, hook to throttle linkage, pull the cable right and put a cable stop on it.
Back to, am I left with needing another trans?
Or will getting a new valve body, pump, governer, TV cable and a bracket for it work?
Old Apr 26, 2014 | 07:09 AM
fervernt's Avatar
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
Re: do i need a new trans?
I would personally just get a different trans. with all the broken stuff you found just from a basic check, I can only imagine what else might be wrong. you could replace all those things but I imagine that wont be cheap, and if it has deeper problems you would just be wasting all that money and still have to replace it anyway.
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
