Would this transmission fit my car?
Old May 1, 2014 | 10:17 AM
stevenr9999's Avatar
Car: '88 Camaro IROC-Z
Engine: 5.0 TPI
I think my 3-4 clutch pack is worn. she won't shift into 3rd. Maybe it just needs a tune up, probably alot of gunk buildup in there. All my gears work good, just 3rd won't budge. Anyway, in case I need a swap I found one for my '88 IROC. 5.0 w/ 700r4
http://miami.craigslist.org/mdc/pts/4374418937.html
There's the ad it came from a 1990 Fleetwood. Do you think it would bolt right in? Which model/year cars would bolt right in without having to mod the tail shaft etc?
Old May 1, 2014 | 04:08 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Would this transmission fit my car?
Do this and it should bolt right in.
https://www.thirdgen.org/forums/post...537-post2.html
I would consider NOT using the torque converter that came out of the Caddy. Use the one that's already in your car.
If you're not willing to swap extension/tail shaft housings, find a 700R4 from another 3rd Gen Camaro or a Firebird.
Old May 1, 2014 | 05:36 PM
Engine: 5.0 TPI
Thanks, just trying to get multiple opinions.
Old May 1, 2014 | 06:06 PM
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
If 3/4s are gone it will neutralize shifting 2/3. Not sure what you mean "it won't budge"???
Old May 1, 2014 | 06:10 PM
Engine: 5.0 TPI
It just won't shift into 3rd. Stays stuck in 2nd.
jhawkeye
May 25, 2022 06:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
mizz0313
Aug 12, 2015 06:45 AM
milk
Aug 10, 2015 06:26 PM
