Tko 600 help
Old May 7, 2014 | 09:06 PM
bbc632's Avatar
Car: 1990 z
Engine: 383 small block chevy
Transmission: tko 600
Axle/Gears: strange dana 60 4:10
Tko 600 help
I have a new in the box tko 600, putting it in my 84 camaro and I have the right cross member but I'm kinda stuck atm with the bellhousing and and our hydraulic clutch set up I don't know what I need to work with our cars thanks
Old May 7, 2014 | 10:09 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Re: Tko 600 help
which tko 600 did you purchase? reason i am asking is they have two different options / One has a longer input shaft than the other. The ford version hase the longer input shaft. You will need a spacer between the transmission and bell housing.
it moves the trans to the correct angle and location for our third gens. As for the hydraulics you may use the existings ones which will work just fine.
Old May 7, 2014 | 10:46 PM
bbc632's Avatar
Car: 1990 z
Re: Tko 600 help
I got the new tko from jegs the 600 for GM 5009 with the. 64 5th. And what bellhousing and do I need to run a hy. Throwout bearing?? Thanks for your help
Old May 8, 2014 | 09:46 AM
Re: Tko 600 help
You can run a stock t5 bellhousing with the adapter plate. I take it you already have a hydaulic setup so you can use that. Get yourself a roller pilot bearing and a new throwout bearing.
Old May 8, 2014 | 07:37 PM
bbc632's Avatar
Car: 1990 z
Re: Tko 600 help
Okay that was what I was going to ask next. I have the t-5 bellhousing and all the hydraulic clutch stuff that came with the car the car is a factory 5 speed. So I just need the adapter plate, yoke, cross member and maybe shorter drive shafts?
bbsr72
Apr 2, 2016 09:12 AM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
aharvel50
Sep 21, 2015 07:31 PM
makaveli09
Sep 15, 2015 10:43 AM
