trans cause of death?
Car: 1986 IROC-Z28 & 1987 GTA
Engine: 305 TPI & 350 TPI
I found this when I took the tailshaft housing off of my 87 GTA's 700r4
Could this be why I only had first gear?
Obviously its a gear, but can someone tell me what its called? & If I replace it will this trans be fine?
It was getting water in it due to a radiator malfunction & I have another tranny to put in the bird already, but I def wanna rebuild this one. Perhaps I dont need to?
Car: 1983 Mecham MSE Trans Am
Axle/Gears: 10 bolt Posi, 3.something
Re: trans cause of death?
No. That gear of for your speedometer. Replacing the gear will get your speedo working, but I'm guessing you have other issues with the trans. If it had water in it, the clutches are most likely toast.
Find another one, they are not hard to locate.
Yes, it could.
That's your governor gear. Without that, the trans always thinks you're sitting still. Not much reason to shift if the car's not moving, eh??
Replace it and see what happens. No guarantees but that at least accounts for not shifting out of 1st.
My speedo is working fine.....
Thanks soFa kING DOM!
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
