need some info on t56 and 12 bolts
Old May 21, 2014 | 08:39 AM
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
T56 swap pics I need to see the hole for the shifter and master what size bit to use.
If I grab a strange 12 bolt does it use the stock length drive shaft.
Going from 700r4 to t56.
Old May 24, 2014 | 12:33 PM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Re: need some info on t56 and 12 bolts
I can tell you that just swapping the trannys, you can reuse the same driveshaft. Dont remember if the moser 12 bolt requires a shorter driveshaft though. Hope that helps.
Old May 24, 2014 | 12:38 PM
Sojer's Avatar
I know it will work with t56. Im going from 300 rwhp to 750 so I need to order a drive shaft.
AussiePr0nCar
Mar 6, 2020 04:04 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
19irocz85
Aug 26, 2015 07:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
