4l80e what mods needed?
Old Jun 5, 2014 | 01:28 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
HI im wondering you that have the 4l80e in your cars. What kind of special mods you had to do to install it?
Old Jun 5, 2014 | 05:10 PM
project89's Avatar
Re: 4l80e what mods needed?
im about to do mine here soon to replace the th400 , u will need xmember and either fab up a tq arm mount or get a xmember mounted tq arm.
need a new drive shaft
and i think i read u need to do a lil bit of banging in the tunnel with a big hammer for clearance in a few spots
Old Jun 6, 2014 | 12:17 PM
jonarotz's Avatar
Car: 91 Z28
Close...You will need to fab up a cross member and torque arm mount, you can use your stock drive shaft, I didn't have to do any hammering to get mine in. I am using an early model year trans though.
You will also need a way to control it...oh don't for get shifter linkage.
All in all not a hard swap...glad I did it. I beat the hell out of it and it holds up great.
Old Jun 6, 2014 | 01:22 PM
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
Been wondering this myself???? Measuring the 4L80E I acquired it measured 1.5" longer than the 4L60E so driveshaft shortening would be a must.
Old Jun 6, 2014 | 03:59 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Well i dont mind banging the tunnel well just the actual fabricating work is what i can't do thats why wanted to see what needs to be done. Ima be running about 480rwhp n/a with a 150 shot so im trying to see if im best buying a built 4l60e or just buying a 4l80e. Ima be runnins lsx so i got a way to control it
Old Jun 7, 2014 | 02:53 AM
project89's Avatar
as somone who has blown up more then a handful of built 700/4l60's spend the extra money the first time and put the 4l80 in , u will spend alot less money in the long run
Old Jun 7, 2014 | 09:16 AM
skinny z's Avatar
So the consensus is that the drive shft tunnel doesn't have to cut up and severly beat up to fit this trans? I've seen the 4L80 and 4L60 side by side and the 80 looks pretty beefy in comparison.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
matthew911
Aug 12, 2015 09:38 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
