Drive shaft
Car: 1986 I roc
Engine: 494 bbc
Transmission: turbo 350
Drive shaft
I have a th 350 trans with a 6" tail shaft going in a 1986 camaro can any one tell me what length of drive shaft I need from the center of the u joint thanks
Car: 1983 Z28
Engine: 385 Fastburn
Re: Drive shaft
Do you have a stock driveshaft available? (out of a 700R4 car)? Because if so the driveshaft you need SHOULD be exactly 3" longer than what the stock one measures. Because a TH350 with the 9" tailshaft doesn't require driveshaft modification.
I think.
I think.
Car: 1983 Z28
1992rs/ss
16
Jan 28, 2016 09:58 PM
Ozz1967
Aug 16, 2015 10:23 PM
