question about T5 removal.
I have a 1986 base firebird with a manual T-5 transmission that needs the throwout bearing replaced. i have removed all the bolts necessary and have almost removed the transmission from the bell housing but can not due to the shifter in the way. the **** screwed off, will the rest of the stick do the same? i felt no screws/nuts and bolts connecting it.
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: question about T5 removal.
It's bolted directly to the transmission tailshaft. You have to remove the center console, then the rubber boot underneath. The you can get to the bolts.
Easy enough to put a floor jack under it, take out the crossmember, lower it, and use a 13mm wrench to take the shifter bolts out.
