automatic shifter lose?
Old Jun 29, 2014 | 07:09 PM
91camarox's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Hi guys so my shifter is lose I believe tranny works fine but when I try to put it in say reverse it skips like it's lose it bumps out as well its almost like its not lined up with the spots where it us suppose to stop also today I had to force it into park any help will be great
Old Jun 29, 2014 | 07:50 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: automatic shifter lose?
Please complete your profile so we know what your working on/with.
I would confirm that the manual shift cable is properly adjusted.
1. Put the shifter in neutral.
2. Raise the car.
3. Crawl under the car and remove the cable at the transmission shift lever.
4. Rotate the transmission shift lever clockwise all the way. This is PARK.
5. Now rotate the shift lever counter-clockwise two detents. This is now NEUTRAL.
6. Re-attach the cable at the shift lever. Torque the nut to 11 ft-lb (132 in-lb).
7. Lower the car.
8. Confirm that the shifter operates correctly.
Old Jun 29, 2014 | 07:53 PM
91camarox's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Sorry its a 91 camaro rs 305 automatic just doesn't seem to wanna grab the park or drive or reverse its easy to go to far
Old Jun 29, 2014 | 08:20 PM
91camarox's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Also do I leave it in neutral when reattaching cable
Old Jun 29, 2014 | 08:58 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
YES.
bjpotter
Oct 4, 2015 07:48 PM
ndndndnd
Sep 28, 2015 08:00 AM
