700r4 Quick Question
Old Jul 16, 2014 | 12:56 AM
penguinpanda0's Avatar
Car: 1987 IROC-Z Camaro
Engine: 305 LB9
I believe my trans has been leaking fluid from where the driveshaft slips in. What is that seal called? In case the seal is not the problem, what are some common reasons it might be leaking from the rear?
Old Jul 16, 2014 | 03:24 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: 700r4 Quick Question
That seal is called an "extension housing seal".
If you're going with the shotgun approach, remove the extension housing from the transmission. Remove the seal and the bushing that's behind the seal and replace them both.
Before you put everything back, make sure you replace the big square section o-ring that seals the extension housing to the transmission case.
The fluid may also be coming from someplace else and blowing all over the back of the transmission.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
