Gears from a 4th gen into a 3rd gen rear
Old Jul 19, 2014 | 03:14 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
I'm looking to put a 3.42 rear in my car, but I want to retain the stock width rear and not have to mess with brakes. Finding a 3rd gen rear with 3.42 near me is close to impossible, plus I'd also like the better zexel torsen posi unit. I'm aware the 3.42 gears out of a 4th gen will not fit in the 2.73 carrier in my car, but I have a 3.23 rear out of my 86 Z28. Will they swap into that? I know I'll also need the updated 28-spline axles, but that isn't a concern of mine.
Old Jul 19, 2014 | 03:58 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Gears from a 4th gen into a 3rd gen rear
If you are changing axles, diff (Zexel), and gears it will work in the 2.73 rear.
Old Jul 19, 2014 | 04:24 PM
big gear head's Avatar
The rear end housing is not different from one gear ratio to another. It's the differential that is different. If you are installing a 3.42 gear with a 3 series Torsen differential then it will fit in any 7.5 housing.
Just be aware that you must set the pinion depth, bearing preload and backlash any time you change the gears.
Old Jul 19, 2014 | 04:47 PM
Engine: LB9, LS1
Ok thanks guys, I just wanted to confirm. I'd like to use the rear out of my Z28, because I like to keep everything original to my car. I know my car is nothing special, but that's the way I am. The Z28 is a parts car that's gonna be hitting the scrap yard soon.
I'm not exactly knowledgeable when it comes to rear diffs, as you can probably tell, so I'll most likely have a shop install the gears.
Does this listing look like it has everything needed for the swap(except the axles)?http://www.ebay.com/itm/10-bolt-OEM-Zexel-Torsen-posi-unit-with-3-42-gears-/281371397209?pt=Motors_Car_Truck_Parts_Accessories&hash=item41830acc59&vxp=mtr
Old Jul 19, 2014 | 04:53 PM
TTOP350's Avatar
You also may want to confirm that your car has the 10bolt and not a 9bolt.
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
redmaroz
Aug 16, 2015 11:40 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
