2 or 3 serious carrier?
Old Jul 25, 2014 | 12:41 AM
MustangBeater20's Avatar
Car: 1991 Camaro RS
Engine: Built TBI 350
Axle/Gears: 3.42 Posi
I'm new to rear ends. I'm wondering if I need a 2 or 3 series carrier? I have 91 camaro rs with the stock 3.08 gears .
Old Jul 25, 2014 | 12:48 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: 2 or 3 serious carrier?
Series 2 for stock gears 2.73-3.08.
Series 3 for stock gears 3.23-3.42.
Series 3 can fit a series 2 with a spacer. IIRC 1/4".
Old Jul 25, 2014 | 01:11 AM
Car: 1991 Camaro RS
Will a 4th gen carrier fit in a 3rd gen? They're both 7 5/8..
Old Jul 25, 2014 | 07:12 AM
big gear head's Avatar
Yes, it will fit. The '91 also has 28 spline axles. This is where you have to be careful. The '89 and earlier 7 5/8 and 7 1/2 inch rear ends had 26 spline axles and the '90 and later had 28 spline axles.
The 2 series is for 2.14 to 3.08 gears and the 3 series is for 3.23 to 4.56 gears. There are special thick 3.23 to 4.10 after market gears that are made to fit the 2 series differental, but this does not apply to GM gears.
Old Aug 19, 2014 | 07:00 PM
jahblah's Avatar
Car: 87' Firebird Formula
So if your going from 2.73 to 3.73, you need a spacer? can that spacer also be purchased on summit?
Old Aug 19, 2014 | 08:23 PM
DO NOT use a spacer. They are nothing but trouble, especially in the 7.5 rear end. There are special gears for the 7.5 that are made thicker for use on the 2 series differential.
Old Aug 19, 2014 | 08:52 PM
jahblah's Avatar
thanks big gear head. that idea is out now. dont need ANY trouble back there. summit gave me the option to choose 3.73 for a series 2 carrier so that should take care of everything. here's the link in case others in my shoes need it:
http://www.summitracing.com/parts/sum-741012
Old Aug 22, 2014 | 09:46 PM
Car: 1991 Camaro RS
Do they make a 3.42 ring and pinion for a series 2 carrier?
Old Aug 22, 2014 | 10:50 PM
Yes.
Old Sep 1, 2014 | 09:14 PM
NASCAR's Avatar
Car: 89iroc/03dakota
Engine: 350&4.7
Transmission: auto
Axle/Gears: 2:77 & 3:55
I have 9 bolt with 2:77s You said summit had 3series for 2series
Old Sep 2, 2014 | 06:56 AM
Not for the 9 bolt. The thick gears are only for the 7.5 10 bolt. You will need a 3 series differential for the 9 bolt.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
gord327
Oct 3, 2015 01:25 PM
georgiaslim45
Sep 9, 2015 08:12 PM
georgiaslim45
Sep 9, 2015 08:11 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
