How much difference in feeling does Auto to T5 swap make?
Old Aug 20, 2014 | 02:33 AM
JunJun's Avatar
Car: 92 camaro convertible z28
Transmission: Swapped from 700R4 to T5
Axle/Gears: Stock Posi. Ratio is not known
I'm planning to swap my automatic to T5.
I certainly want a pleasure of changing the gears myself, but also want a better feeling (I hate Auto's slippy feeling).
How much difference do you feel after the swap?
Is it worth doing that?
I don't care much about the actual speed, like 0-1/4 mile time.
I do care the feeling and the pleasure of shifting gears and revving the engine.
I appreciate opinions of the owners who actually swapped the transmission.
Thanks.
Old Aug 20, 2014 | 07:01 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: How much difference in feeling does Auto to T5 swap make?
It will completely change the car. It will be a little faster but more importantly you will have more control over what the car does and when.
Old Aug 28, 2014 | 10:29 PM
ht4100's Avatar
Car: 86 Z28, 86 Seville, 98 Isuzu Rodeo
Engine: 383, HT4100, & 3.2 V6
Transmission: World Class T-5
Axle/Gears: G92 3.23
Best modification I have done to my car, no regrets. I went from a 305TPI to a 383TPI, then from Auto to manual. If I had choice I would rather have a 305 5 speed than a 383 auto. It completely changes the car, much more fun to drive. I put a pro5.0 short throw shifter when I did the swap, would recommend that.
Old Aug 29, 2014 | 03:10 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Same.... I'd rather have a 305 T5 car than a 350 A4 car.
Old Aug 29, 2014 | 06:05 AM
JunJun's Avatar
Thank you guys.
I was a little bit worried about my 305 engine because it's not so powerful.
But after hearing your impressions I no longer have any hesitation to swapping to a manual.
As you said, I need more control and more fun.
My 305 engine makes a nice sound when revved thanks to a Borla, so I hope a manual trans can make it a lot easier to enjoy the sound together with a direct feeling.
I need some time to save money, but I'll definitely go for the swap soon.
Old Aug 30, 2014 | 03:25 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
search my name. i did it pretty recently and did a whole write up about it. if you plan on doing this you WILL need a parts vehicle
Linson
Oct 24, 2025 02:00 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
Zell1luk
Sep 29, 2015 10:36 AM
6998poncho
Sep 25, 2015 02:56 PM
