Surface rust on steel in rebuild kit?
Old Aug 20, 2014 | 05:33 PM
Russell Baird's Avatar
Car: '86 Trans Am (White)
Engine: Its a tree fiddy
Transmission: 1/2 of a 700r-4
I just got my 350 turbo rebuild kit in from summit, b&m kit, and it appears to have surface rust on it. Is this common or is it a defective product?
Old Aug 20, 2014 | 07:20 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Surface rust on steel in rebuild kit?
I would say it is not common but not defective either. How many plates are like that?
I'd call Summit and see what they'll do for you.
Unless those plates are of special thickness or made from un-obtainium, etc., it might be cheaper and faster to just order some replacements from Makco.
I don't know if this is an acceptable practice but some real fine steel wool and some clean ATF might remove that if it's only surface corrosion.
Some experts might even say it won't hurt to install them as-is.
Old Aug 20, 2014 | 10:27 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
This. And if it's just one out of a clutchpack and able to be used as a first or last piece, facing it away from the friction works.
Old Aug 21, 2014 | 12:24 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Excellent idea!
Old Aug 24, 2014 | 09:44 AM
I didnt open the package yet so it may be more, but as of now its just the one. I'll just put it on the end, first tranny rebuild so im being a little careful.
Old Aug 24, 2014 | 11:55 AM
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
I vote to send it back. I worked for Ceva's (eaton parts for semi truck transmissions) QC department and a number of parts that had came back to be reworked had rust.
Old Aug 24, 2014 | 12:24 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
IMO, it's much easier to return if it's unopened.
italiano67
Dec 11, 2016 09:21 AM
92GTA
Apr 9, 2016 07:39 AM
hectre13
Sep 8, 2015 03:38 PM
someone972
Aug 30, 2015 12:52 AM
