Is this normal?
Old Aug 30, 2014 | 05:52 PM
tomsaddy's Avatar
Car: 1987 GTA
Engine: TT LC9
Axle/Gears: 3.50
Is this normal?
I'm installing an MN12 T56 from a CTS-V into my 3rd gen. I installed an f-body extension housing and the top and bottom machined surfaces are at a significant angle. The shifter mount and trans mount appear to be affected. Has anyone else seen this?
Old Aug 30, 2014 | 08:45 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Is this normal?
Yes the early 4th gen and late 4th / GTO all exhibit this.
Old Aug 30, 2014 | 10:04 PM
jmd's Avatar
jmd
Re: Is this normal?
Old Aug 30, 2014 | 10:07 PM
jmd's Avatar
jmd
Re: Is this normal?
Originally Posted by jmd
Old Aug 31, 2014 | 08:01 AM
tomsaddy's Avatar
Car: 1987 GTA
Engine: TT LC9
Axle/Gears: 3.50
Re: Is this normal?
Interesting. Now I'm less concerned, but more curious. Any idea why?
Old Aug 31, 2014 | 10:59 AM
jmd's Avatar
jmd
Re: Is this normal?
It doesn't cost more to stamp a crossmember with a 6 deg slant. And the way the stock shifter stick bolts on, it had room for the rubber isolator and it's centered to the console. Designed to a cost.
The 32 spline housings aren't like that.
How is your hybrid buildup coming along?
Old Aug 31, 2014 | 12:48 PM
tomsaddy's Avatar
Car: 1987 GTA
Engine: TT LC9
Axle/Gears: 3.50
Re: Is this normal?
Not too bad. It's my first experience with a manual transmission, so it's been pretty educational. I want to do a 32 spline SSR mainshaft, but they seem to be backordered everywhere. I'll then have to have the tail housing machined for the larger bushing and get a TH400 yoke. It should be a pretty stout transmission when complete.
I read that I need to go with an LS7 slave to avoid having to use spacers and such, so I got one of those and the appropriate pilot bearing. We'll see how it goes from here.
Fanatic1074
Oct 3, 2022 05:57 AM
Linson
Oct 1, 2015 09:50 PM
dusterbd
Sep 29, 2015 08:40 AM
BWilcox
Sep 20, 2015 12:19 PM
Stroopwafel
Sep 11, 2015 06:38 AM
