W.c t5 with ram hd clutch set
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Ok so i got a ram hd clutch kit that is ment to hold up to 500hp motor only got about 300 whp on a 355 hsr build but my problem is that i just installed this clutch brand new got a new t5 flywheel and all but the clutch wants to grab super high pedal almost at full return what did i mess up on any feedback will be great
Engine: 4++,350 & 305 CIs
Re: W.c t5 with ram hd clutch set
Sounds like a normal new clutch to me.
Engine: LR4 4.8
Really i always thought a new clutch would grab low at the bottom near the floor pan not all the way up maybe the pressure plate bolts are to tight or something
