Recommendations for Posi Parts Manufacture
Old 09-22-2014, 09:57 AM
roysatikas's Avatar
Car: 91 RS
Engine: 4 bolt 350, .060 over
Transmission: 700R-4
Looking for any recommendations and successes any of you may have had with a 10 bolt-7.65 Posi install. I installed Yukon 28 spline axles and bearings a last year and am ready to purchase the parts now for the posi install. What brand (s) / manufacture do you recommend?
Thanks to all for your input,
Roy
Old 09-22-2014, 10:00 AM
big gear head's Avatar
Re: Recommendations for Posi Parts Manufacture
The Eaton Posi is a good unit for most street/strip use. If you want something a little cheaper then the Yukon Dura Grip is also good. The Eaton Truetrac and Torsen are also good. You can sometimes find the Torsen used on ebay. Just DO NOT get the Auburn or Eaton Governor Lock.
Old 09-25-2014, 11:50 AM
roysatikas's Avatar
Car: 91 RS
Thanks for the posi parts manufacture recommendation Big Gear Head.
Sincerely,
Roy
Old 09-26-2014, 02:41 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I rebuilt my 10 bolt recently...
Went with the Eaton True Trac over Posi for a few reasons... No clutches to wear... and the Posi gives more power to the wheel that's slipping, the True Trac gives more power to the wheel with traction...
I got Richmond gears, Yukon rebuild kit, LPW Cover & Brace, Motive / Factory 10 28 Spline axles...
Very happy so far...
Old 09-27-2014, 08:20 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
The Eaton Posi and Yukon Dura Grip do not wait for a tire to slip and is using a clutch pack at a minimum of 400 lbs preload. and that is magnified with torque applied.
That means you have positive traction with both tires ,no tire slip necessary.
http://www.eaton.com/Eaton/ProductsS...als/PCT_339923
Link = https://www.thirdgen.org/forums/tran...de-photos.html
Works perfect for my application. (street use for now)
hectre13
12-11-2023 08:14 AM
LT1Formula
20
11-14-2015 12:02 AM
armybyrd
08-17-2015 08:59 AM
GVMV
Exterior Parts for Sale
08-16-2015 07:08 PM
1nastygta
08-08-2015 07:38 PM
Quick Reply: Recommendations for Posi Parts Manufacture
