T10 from ford falcon fitting in 3rd gen camaro?
Old Sep 28, 2014 | 02:18 PM
Smakz420's Avatar
Hey so I have been on a hunt for a t56 or t10. So the only thing I'v been able to find for a decent price in nevada is a t10 from a 63 ford falcon. my question is will it fit in a 3rd gen camaro?
Old Sep 28, 2014 | 03:02 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: T10 from ford falcon fitting in 3rd gen camaro?
Transmission, maybe. Bellhousing, no.
Old Sep 28, 2014 | 06:52 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
Why would you even want a T10? Unless your car was originally equipped with one (highly unlikely), you'll need to swap out all the pieces you would need to with a T56. By the time it's all said and done, you'll have spent as much as you would swapping in the 6-speed, and be left with a sloppy shifting 4-speed and can't take the car on long trips.
Old Sep 29, 2014 | 07:19 AM
No.
Bolt pattern to the BH is different, mount is different, splines on the clutch are different, drive shaft is different, finding a BH (unless you go $$$aftermarket$$$) is EXTREMELY tough (one-year-only: only 82 will fit, along with ALL of its associated parts), shifter near impossible to find any more, no torque arm mount.
Not a good candidate. "Possible" for those who are willing to do considerable fabrication, adaptation, and other monkey-motion; FAR from bolt-in. One of those "if you have to ask, it's not for you" type things.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Vintageracer
Aug 11, 2015 08:13 PM
beachrodder
Aug 7, 2015 04:27 PM
