Same clutch & flywheel?
Old Oct 11, 2014 | 01:23 AM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
I pulled a t5 that was swapped into an 82 camaro with lg4 and will be using it with a 91 350. Will the clutch and flywheel be different since I'm going from a 2 rms to a 1rms?
Old Oct 11, 2014 | 12:53 PM
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Re: Same clutch & flywheel?
Clutch should be the same.
Flywheel needs to match the rear main seal type.
Old Oct 11, 2014 | 08:22 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Can I just order a flywheel for a 87 - up 350?
Old Oct 11, 2014 | 09:27 PM
RamIt's Avatar
Car: 1984 z28
Yep. Just get the 305's 10.5" flywheel.
No 350's came with 5 speeds but the 305''s flywheel is correct.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
