Rear End Swap
Old Nov 13, 2014 | 09:13 AM
Krye3rdGen's Avatar
Rear End Swap
going from a 91 Camaro RS with an open diff/drum brakes to a 92 firebird formula with LSD and disc.
How much extra stuff do I need to get? Is it just a take off and put on swap or is there some machining required?
Old Nov 13, 2014 | 09:33 AM
big gear head's Avatar
Re: Rear End Swap
No machining. You will need some of the brake parts to make the disc work correctly. Otherwise it's a bolt in.
Old Nov 13, 2014 | 09:54 AM
Krye3rdGen's Avatar
Re: Rear End Swap
Thanks!
Some of the drum brake parts or order stuff?
Old Nov 13, 2014 | 03:44 PM
Re: Rear End Swap
Parking brake cables and some of the hydraulic parts will need to be changed.
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
