4th gen driveshaft
Old Dec 31, 2014 | 11:43 AM
gmoutdoorsman's Avatar
4th gen driveshaft
Wanting to swap my stock steel shaft for a lighter aluminium one out of an LS1 4th gen. Im doing LS swap with 700r4. As long as I get a driveshaft from an auto car will it fit?
Old Dec 31, 2014 | 03:21 PM
Re: 4th gen driveshaft
Auto & stick drive shafts are the same, and all fit all of these cars. (except for the very early ones w T200C or 4-speed)
Just make sure it's not one of those with the cardboard box material stuffed inside to pretend to be damping material.
Old Jan 1, 2015 | 08:35 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Several years ago I installed a 4th gen aluminum driveshaft in my 1986 IROC-Z when I I installed a disc brake rear. But it appeared to be about an inch too long. I had to unbolt one of the lower control arms and pry the rear back to install it. The driveshaft is currently removed while I am replacing the fuel tank. My question is; what length should the driveshaft be, and how do I measure it?
Old Jan 1, 2015 | 08:38 PM
ANDYZ28's Avatar
Car: 1982 Z-28
I measured my 4th gen aluminum driveshaft and it is 7/16" longer than a stock 3rd gen steel driveshaft. The difficulty in installation seems to be due to the larger "boss area" of the u-joint end of the driveshaft. I will try to get it shortened and post the results.
Thanks, Andy
sweet_87_iroc
Sep 25, 2015 10:01 PM
cam-mike
Aug 24, 2015 07:23 AM
