700r4 vs 4l60
Old Jan 25, 2015 | 09:09 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
700r4 vs 4l60
hey guys got an odd question. my buddy has a 93 firebird lt1 4l60 car. keeps having transmission problems. it is a cable operated 4l60 my question is what all would it take to put a 700r4 back in it. he doesn't care if it throws a code just wants to drive it. everything ive read says the cross member mounting is different. whats different about it? and will there be anything else he will have to do.
Old Jan 25, 2015 | 09:21 PM
Re: 700r4 vs 4l60
700-R4 = 4L60
Same exact identical no difference thing
Sometime around 89-90ish, GM decided to rename their whole transmission line in a "standardized" fashion.
4 = # of gears
L = longitudinal (front-wheel-drive cars are "T" for "transverse")
60 = some arbitrary relative torque "rating"
700-R4 of course means absolutely nothing whatsoever; just yerbasic pluck-from-anus random number.
Forget about those "numbers". Your friend's car doesn't care what "number" its transmission is assigned.
Crossmember is absolutely identical in every way, since the 700-R4 and 4L60 are the same thing.
What is the transmission actually DOING? Maybe we can help him fix his 700-R4/4L60. Chasing after those "numbers" or "model names" is a waste of time, maybe we can actually HELP.
Old Jan 25, 2015 | 09:44 PM
ziggy89's Avatar
Engine: 383
Re: 700r4 vs 4l60
I knew all that already just wanted to make sure the mounts line up. I know they make different cross members for 4l60e swaps. any way his transmission is dead again. slips like a ****. fluid is good and tv cable is adjusted properly.
Old Jan 25, 2015 | 10:03 PM
Re: 700r4 vs 4l60
Sure; for cars that didn't come with 700s.
4L60E = 4L60 aka 700-R4, except with electronic instead of mechanical valve body control
No difference whatsoever in anything to do with the trans mount or crossmember.
So yeah, mounts will line up; assuming of course that the trans has a F-body (torque arm) extension housing on it.
Old Jan 25, 2015 | 10:36 PM
ziggy89's Avatar
Engine: 383
Re: 700r4 vs 4l60
Tail housing can be sealed eas . Or get a different torq arm mount. PS they make 4l60e swap cross members for third gen cars when using and ls motor and trans. Those mounts are obviously differen . Didn't know if the Lt cars were too.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
