Need torque converter help!!!!!!
Old Feb 22, 2015 | 04:09 PM
Amaro83's Avatar
Car: !983 Z28
Engine: 355
Transmission: rebuilt 700R4
Axle/Gears: possi rear end
I have a 1983 Z28 that I am putting a 355 small block in. New cam and lifters. New roller rockers. The whole works!! Completely rebuilding the 27 spline tranny. Putting a corvette servo, shift kit, and high performance springs in. Here is where I need the help. I am lookin to get a 2400-2800 stall converter. Anybody have any suggestions on which one to use? Thanks for the help!!
Old Feb 23, 2015 | 04:01 PM
Cosmik Debris's Avatar
Re: Need torque converter help!!!!!!
You will need to give more info about the engine. The cam specs, compression etc for someone to recommend a converter.
Old Feb 23, 2015 | 05:21 PM
Amaro83's Avatar
Car: !983 Z28
Engine: 355
The cam is an Erson flat tappet hydraulic flat tappet cam. I have the cam sheet. Just not sure which numbers are needed to tell that. Here are a few of the numbers off of the sheet;
Overlap-70.00
Duration(int/exh) 284/296
I hope this helps some. If you need more info, just let me know!!
We won the engine at a car show about 5 years ago. It has been rebuilt by an engine shop. It is a 350 bored 30 over. My husband is an auto technician, and he says everything looks to have been done right!!
Old Feb 25, 2015 | 02:57 PM
Amaro83's Avatar
Car: !983 Z28
Engine: 355
I have done some research on converters, and people seem to like the Vigilante, Yank, and the Boss Hog. Anybody have any experience with these?
Old Feb 25, 2015 | 03:29 PM
Yes all those are good, also take a look at Circle-D, Brian there is very helpful. I suggest you contact him or someone at the other companies you mentioned and they will extract the information they need from you and recommend a converter for your application. It is almost always better to get a custom tuned converter than an off the shelf one.
seiplentz
Aug 19, 2019 06:02 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
