What transmission should I use!?!?!?!?
Old Feb 23, 2015 | 05:21 PM
Firebird1012's Avatar
Car: 1991 Pontiac Firebird Trans Am
Engine: 305 v8 5.0L Lb9
My baby has been sitting for a while with a blown 4l60e in it and I'm trying to find a transmission that would hook up to the stock 305.
BUT I am also looking to do an engine swap do to the sock one having 210k miles and I am looking for a bit more power so I want to go with an Ls engine pushing 450-500hp to the wheels.
So I will need a transmission that will fit on both the 305 and the ls engine and will also handle the power of the Ls engine. I don't know if this is possible but any information or ideas would be much appreciated!
Old Feb 23, 2015 | 05:26 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
Re: What transmission should I use!?!?!?!?
well your 91 firebird should have a regular 4l60 or 700r4 not and electronically controlled 4l60e. just rebuild the 700r4 in it to hold the power and run it with the ls later.
ps my 700r4 is just the original one from behind my 305 rebuilt and beefed up.
Old Feb 23, 2015 | 07:51 PM
So that trans will hold up to the Ls with no problem?
Old Feb 23, 2015 | 08:19 PM
ziggy89's Avatar
Engine: 383
If built right. I put around 475 to mine with my 383.
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Youngs92
Sep 23, 2015 11:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
