How duarable are the 91 fbody stock rear ends
Old Feb 17, 2015 | 01:35 PM
kad5118's Avatar
Car: 91 gta ws6
Transmission: 700 R4 TRANS
I have a 91 gta fire bird with a L98 I just upgraded a stage 2 transmission from good fellas transmission.this trans is good for 550hp 600 torque.What i want to know is can the stock rear end hang with the a motor that's as powerful as my transmission.
Old Feb 17, 2015 | 03:17 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: How duarable are the 91 fbody stock rear ends
550 Hp...no not long
Old Feb 17, 2015 | 03:57 PM
kad5118's Avatar
Car: 91 gta ws6
your saying it last for long at that power range
Old Feb 17, 2015 | 04:48 PM
big gear head's Avatar
With street tires and no wheel hop it would be all right on the street. With sticky tires it's going to break with 550 to 600 HP.
Old Feb 17, 2015 | 05:25 PM
kad5118's Avatar
Car: 91 gta ws6
ok what are some of the modification i can do to the rear wnd that will help with the stock rear end
Old Feb 17, 2015 | 05:38 PM
Night rider327's Avatar
Car: 1988 Camaro
Nothing....
No upgrades will make these rears live with that kinda power with traction. I broke 2 with less power and only running mid 11's. I then swapped in a moser ford 9" rear
Don't waste your money on the 7.5"/7.625" 10 bolt. The ring and pinion is just too small, axles are too small.
I wasted over $1,000 trying to make mine last and it didn't work, still broke anyway. The ford 9" only ran me about $2200 so I wasted/threw away over half of the price of the 9"
Old Feb 17, 2015 | 06:06 PM
Yea, with that amount of power and good traction you are going to break it no matter what you do to it. Just get a stronger rear end like the 12 bolt or 9 inch and don't spend any money on the 7.5 10 bolt.
Now if the 550 to 600 HP is just a dream and you will only actually make about 300 HP then you can live with the 7.5 if you build it right.
Old Feb 17, 2015 | 08:14 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Do you remember the first level/fight in Mike Tyson's Punch-Out? They're like that.
Old Feb 17, 2015 | 08:18 PM
kad5118's Avatar
Car: 91 gta ws6
lol well its a dream for now until I go through my swap i just slowly building the car around the motor and trans.Its a 4.8 vortec with a hc1 holset turbo(which i currently have)or a gt45 turbo depending on which would be better for my power output.
I know that my transmission was my weak point now it looks like my rear end is also.
Old Feb 17, 2015 | 08:22 PM
Driveline shock is what usually kills the 10bolts. Manual cars are far more prone to breaking them, especially when drag racing. I've got a cammed,headed,full bolt-on LT1 that should be in the 400-430whp area once tuned. Its in front of a T56 and a stock 3.23 10bolt. I'm fully expecting it to break at some point. At which point a 9" or 12bolt will go in its place.
But I'm not drag racing it, I'm road racing and street driving it. So I can be a little softer with the shifts. It still won't last forever though.
I've seen stock 10bolts live behind cammed LS1s making near 380-400whp. But those people have never launched hard on DR's or slicks. They are usually on street tires.
Old Feb 17, 2015 | 08:57 PM
kad5118's Avatar
Car: 91 gta ws6
well i dont plan on putting slicks on it this car and its only only a street car
Old Feb 17, 2015 | 08:58 PM
A hard shift could kill it just as much as the initial launch.
Old Feb 17, 2015 | 10:39 PM
Eric-86sc's Avatar
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
The only thing "going" for the rear you have is it has 28 spline axle shafts over the earlier 26. If I were you I'd put a TA performance rear cover and c clip eliminator in and run the rear till it blows. It'll blow eventually but it may survive a few miles since your running street tires.
Old Feb 17, 2015 | 11:07 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Soooo is the motor stock or what is done to that?
Old Feb 18, 2015 | 06:32 AM
kad5118's Avatar
Car: 91 gta ws6
well its has the stock L98 in it now but i have a 07 4.8 with a holset turbo that's going to be put together the only thing that modified now is the transmission and that came from good fella transmission on ebay
Old Feb 23, 2015 | 10:08 PM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
LOLOLOL (Mike Tyson comment)
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
