Vibration/wobble from rear
Hi guys ,
just took my new project up the road (1985 5.0TPI TA) and noticed that there is a harsh wobble coming from the drivetrain even at low speeds (especially when under load) is there anywhere which is a common weak point on these?
any help would be great
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Vibration/wobble from rear
Check that your axle flanges are not bent.
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Check your trans mount. If it is broken it will move under acceleration and make you think something is broken.
Engine: 4++,350 & 305 CIs
Check your tires and make sure they don't have a broken belt..
Car: 88GTA
Engine: 5.7TPI
A couple more:
Harmonic Balancer
Torque Converter tight
Driveshaft/U-Joints good and seated
Harmonic Balancer
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
