nwc t-5 lost 5th gear... again
Old Mar 2, 2015 | 10:45 AM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
ok so i have a 86 nwc t5 (v8 one) and 5th gear keeps walking past the snap ring like its nothing. ive tried new snap rings, the locktite stuff and 5th gear just keeps doing its own thing. so i was wondering other then buying a new main shaft how to fix this problem, then i realized it looks like the snap ring groove is a bit rounded. so my question is, can i grind that snap ring groove down, even a little deeper, to stop 5th gear from walking past the snap ring? and it not mess up the trans?
Old Mar 2, 2015 | 05:28 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: nwc t-5 lost 5th gear... again
The surface of the mainshaft is hardened and challenging to machine.
The solution used by Tremec on some T56 models and all TR6060 is some of the lock rings were replaced by half-circles with a ring around them. But, without something behind the ring, you lack something to hold that ring.
Since you're machining anyway, I would figure out what fat lock-ring would work in a slightly deeper, wider groove. Maybe 0.030" deeper and whatever it takes to sharpen up the edge of the splines facing the ring.
Old Mar 2, 2015 | 07:30 PM
DARKmj16's Avatar
Engine: 305 tbi
ya i have a drimmel that spins at 10,000 and some pretty pricey cut off wheels. looking at the spines they are a little rounded. not trying to do to much cutting but i need my 5th gear back permanently.
Old Mar 4, 2015 | 03:49 PM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
A dremmel and cutoff wheel won't touch that. You will rip thru wheels without removing much, if any metal. Also, with a dremmel, you will have a hard time (you can't do it) holding the tolerances that a part like that will require. Start looking for a WC T-5
PurelyPMD
May 5, 2016 04:57 PM
Zane Story
Oct 8, 2015 12:40 PM
3.8TransAM
Sep 27, 2015 08:37 PM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
