28 spline axle in 26 housing
Going to install 28 spline carrier, but will 28 spline axle fit into axle bearing of a 26 spline housing? My thought is moser axle"s and eaton 28 spline carrier.
Thanks in advance
Thanks in advance
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Re: 28 spline axle in 26 housing
Should be a direct replacement.
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I installed 28 Spline Moser axles in my 84 to replace the factory 26 spline when I installed a Zexel Torsen diff. Went right in with no issues.
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
The 26 & 28 spline axles are the same diameter at the bearing race, which is the only interface between the housing & the axles. They interchangeable as far as the housing goes.
