Ford 8.8 or 9"? What's the difference and which is better?
Old Mar 1, 2015 | 02:43 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I've been hearing some say they have a 9" and some say they have an 8.8.
I'm not a ford guy, but my Explorer has an 8.8.
What's the difference between them and if looking to install behind some power, which is the better option?
Old Mar 1, 2015 | 04:47 PM
big gear head's Avatar
Re: Ford 8.8 or 9"? What's the difference and which is better?
Most consider the 9 inch to be the ultimate car rear end. It has a larger ring gear, 3 pinion bearings, and the pinion centerline is offset farther below the ring gear centerline than any other car rear end that I know of. All of this makes it one of the strongest rear ends that you can put in your car. It's also easier to modify the housing to fit many different types of car or truck because the housing is all steel, so you can weld on any part of it. On the down side, it also has more parts in it and it takes more power to turn than the other car rear ends. It's more expensive to build a 9 inch if you are using all new parts.
The 8.8 is a very close copy of the Chevy 12 bolt. They both have almost the same size ring gear, use the same bearings on the pinion and differential, are about the same weight and use the same amount of power. They are also about the same strength. Many of the 8.8 rear ends came with 28 spline axles, but many came with 31 spline axles. The 12 bolt has 30 spline axles. The down side is that it cant take quite as much power as the 9 inch if they are both built comparable, and the center of the housing is cast iron, which limits the amount of welding that you can do to the housing.
Numbah-1
Sep 12, 2015 08:57 PM
ronchic
Mid-Atlantic Region
Sep 10, 2015 02:32 AM
J.C. Denton
Sep 8, 2015 05:35 PM
Street Lethal
Sep 7, 2015 01:09 PM
