700r4 falls out of gear problen?
If I drive it normal it shifts fine if I accelerate hard like when I'm trying to past it'll shift then when it's trying to go into the next gear it will then act like the car is in neutral I have to put the shifter into neutral then back to drive and it'll be in the gear it was trying to go into and drive fine.doesn't do it on the same gear just when ever you nail it fluid color and level is good I've tried adjusting the cable it's a 90 tpi
Re: 700r4 falls out of gear problen?
TheTraut88
Sep 7, 2015 05:22 PM
