Speedo gears
Car: 1985 iroc z
Engine: Crate 350
Axle/Gears: 3:24
Speedo gears
Hello, i was wondering if anyone would know what driven gear to get for a w/c b/w t5 im not sure of the drive gears tooth count but i know its red, rear gear ratio is 3:42 tires are 245/50r16 my speedometer is way off and just gets worse going faster it has the mechanical speedometer i have the yellow white-ish driven gear now
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Speedo gears
You will have to change the red for a purple 7 tooth gear drive gear for 3.42's
You have the right driven gear to work with the purple.
The red is 9 teeth.
The red is 9 teeth.
Car: `86 SS / `87 SS
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
