Easy Speedo Gear Question for Experts
Old May 2, 2015 | 10:11 AM
mav75's Avatar
Car: '89 Trans Am
Transmission: 700 R4
I've got a question about the right speedo driven gear for a new rear axle setup I've got. I have a 700R4 auto trans, 245/50/16 tires, and went from a 2.73 to 3.42 rear axle. Do I need a 44 tooth driven gear or a 45 tooth? TIA
Old May 3, 2015 | 12:01 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Easy Speedo Gear Question for Experts
You can use either one to leave your speedo inaccurate.
If you want it accurate, replace the 17 drive gear with a 15 and use a 42 driven.
Old May 3, 2015 | 12:05 PM
jmd's Avatar
jmd
Old May 3, 2015 | 01:53 PM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
This is why we have the stickies.
https://www.thirdgen.org/forums/tran...eedometer.html
Old May 3, 2015 | 04:19 PM
mav75's Avatar
Car: '89 Trans Am
Originally Posted by cosmick
Why do I need to replace the drive gear? I did look at the sticky and did the math. I came up with a 45 driven gear. Also, the website below also had a chart saying I need a 45 driven gear with a 17 tooth drive gear.
http://www.transmissioncenter.net/sp...f2bhoCI8zw_wcB
Old May 3, 2015 | 08:12 PM
jmd's Avatar
jmd
Read this post: https://www.thirdgen.org/forums/tran...ml#post5294515
and this thread:
https://www.thirdgen.org/forums/tran...ter-gears.html
And then do whatever your heart desires.
Old May 3, 2015 | 08:52 PM
mav75's Avatar
Car: '89 Trans Am
The post with that chart you posted with tire sizes and gear ratios was very helpful. I couldn't find that chart in my shop manual. Thank you.
Jorlain
Aug 24, 2022 05:11 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
