RAM powergrip HD high engagement
Old May 11, 2015 | 02:38 PM
robbe_iroc's Avatar
Car: 1989 Iroc
Engine: LS2
Transmission: GTO T-56
Axle/Gears: 4:th gen Auburn with 3:73
I installed a new RAM Powergrip HD complete with their billet steel flywheel just before the winter, drove it for a few day, and then the car has been in the garage until now when the snow starts to clear.
The scary thing is that the clutch engagement point is just as the pedal nearly is completely at the top/up position. I get some chatter and then I can move the pedal about half an inch(10-12 mm) or so.
I have gotten the TICK Mastyer cylinder, and the updated GM slave 2001+ in my T56/MN12 LS2 swapped Iroc.
What could be the reason for this? The car drives, but it feels like as if the clutch is totally worn out
I did not use a shim behind the slave.
cowansauto
Apr 3, 2025 12:51 PM
Elephantismo
Feb 13, 2019 12:51 AM
sahlomonic
Sep 20, 2015 07:15 PM
R3500
Sep 8, 2015 10:12 PM
09ave
Sep 7, 2015 06:03 PM
