Electric speed sensor confusion
Old May 30, 2015 | 04:25 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Hey guys, would my 86 trans am 305tpi be an electronic or cable driven speedo?
The reason I ask is because I ordered a speedo drive gear since I forgot to put one on when I got my rebuilt transmission, I took the tail shaft off and speed sensor off and realized there's a magnetic speed sensor on the tail shaft.
Here is where it gets confusing, Before I bought a rebuilt transmission I put several different junkyard transmissions in my car, I have a large feeling I accidentally put a magnetic speed sensor in the rebuilt transmission from a junkyard transmission instead of the gear driven one that originally came with the car but I'm not entirely sure.
Edit: so I figured out I have the correct speed sensor but I don't get how I'm supposed to put a driven gear on the speed sensor. One side has a magnet while the other side has a small hole
Old May 30, 2015 | 06:57 PM
spicyskater's Avatar
Car: 1987 camaro Z28
Transmission: manual
Re: Need urgent help
86 is cable...I think furst year for for electronic is 89
Old May 30, 2015 | 07:50 PM
TylerSteez's Avatar
Engine: 383 stroker
everything else is pointing me to cable as well, Now I just got to order one and have it rushed to my house, drove all around and every parts store didn't sell them
Old May 30, 2015 | 08:04 PM
TylerSteez's Avatar
Engine: 383 stroker
If anyone can point me to a cable vss sensor for an 86trans am 305tpi with a 700r4 I'd greatly appreciate it. I've been looking online but haven't found any
Old May 30, 2015 | 10:38 PM
TylerSteez's Avatar
Engine: 383 stroker
Turns out I do have an electronic speed sensor. Now my question is what drive and driven gear would I use? I don't see any possible way to put a driven gear on this speed sensor, one sides a magnet and the other side is a small hole
Old May 31, 2015 | 03:50 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Electric speed sensor confusion
that is correct.
Figure out if the drive gear is inside.
To do your car like stock, you need an 86-89 VSS and the gears that match your tire size and rear gear ratio.
Old May 31, 2015 | 03:59 PM
TylerSteez's Avatar
Engine: 383 stroker
Originally Posted by jmd
that is correct.
Nope no drive gear inside, I bought a rebuilt trans and they tell you to take the one out of your old trans and put it on which I forgot to do.
I already have the correct drive gear for my rear end, now I just need to find a place that sells the correct vss and then buy a 37 gear driven gear. I can not find a single vss online for my car. I think transmissions center.com may have one but I'll have to wait till tomorrow to call them since they're closed today. If anyone could send me a link for one I'd greatly appreciate it
Old May 31, 2015 | 06:27 PM
jmd's Avatar
jmd
37 is steep.
What tire size and rear gear?
I hope they have the VSS for you.
Old May 31, 2015 | 06:44 PM
TylerSteez's Avatar
Engine: 383 stroker
37 is steep.
Really? I used some online calculators and they gave me a 17/37 drive driven gear number.
My wheels are 26 in diameter and I have a 2.77 rear
BRoss99
Aug 10, 2025 05:08 PM
RazorN8
Jan 7, 2022 11:44 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
mizz0313
Aug 12, 2015 06:45 AM
