Scariest two days of my life, need advice
Car: 86 Trans Am WS6
Engine: 383 stroker
hey guys, so I just finished installing a new speedo and gears into my car along with a new throttle body, torque arm bushing, and trans mount, I put a 37 tooth driven gear in to go with the 17 tooth drive gear on the tail shaft.
On its maiden voyage I was amazed at how much better it ran due to the new throttle body and happy to finally have a working speedo again after a year of not having one, and then I noticed how it shifted..
The trans would try to shift, hang there after its shift and then drop the rpms way low and then it'd chug. I thought my one year old rebuilt 700r4 just bit the dust which would of made a part of me die a little inside. after a bunch of rechecking everything I decided to unplug the new speedo and take it for a drive, problem solved.
Here's my theory, I have the wrong driven gear causing the computer to misread the speed and put it into lockup at a weird time. Does this seem plausible?
Also when I selected the 37 tooth driven gear I did a bunch of online calculations and calculators and that's what I ended up with. What would you guys recommend for 26inch tire diameter and a 2.77 rear?
Car: `86 SS / `87 SS
Re: Scariest two days of my life, need advice
Part throttle shifts are controlled by the throttle valve cable & governor.
Speedo gears are driven by the output shaft in the 700-R4. No way for the speedo gears to impact shifting.
VSS is one of the inputs for lock-up speed by the ECM.
Unplugging the TCC wiring at the trans. for short-term drivability testing is a great way to determine if a TCC solenoid is bad. But it's more likely that you just tooled around with the throttle body and your throttle valve cable is not connected or very mis-adjusted.
An early third gen with 2.73 rear, TH200-C and tires around that height could have had 17 / 37 or 17 / 38 speedo gears. What I'm saying is you're close enough that driveability issues aren't coming from the speedo gear ratio.
Engine: 383 stroker
Edit: also it seemed as if the speedo was reading pretty high
You may need to set minimum air / IAC.
https://www.thirdgen.org/forums/tech...ml#post1304610
Post-shift rpm drop shouldn't be a noticeable issue on an automatic car. With a stick car, not having a VSS signal to the ECM will cause the engine to drop way low and stall when not in gear.
Engine: 383 stroker
