200r4-->th350-->700r4
My car currently has a TH350 in it. It was converted from a 200R4 to a TH350 about 2 years ago. I found out, I really needed overdrive and should have done that in the first place, but what do I need to swap to a 700R4? So far, I know I need a new shifter, go from a detent cable to a TV cable, and of course, the transmission and converter. Do I need to get a new driveshaft? This driveshaft is the same one I had with the 200r4. The crossmember is the same right? Also, what do I need to make the converter lock up?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Your car would have had a 200c, not a 200-4r. You'll probably need a new driveshaft, and I think you'll have to drill a couple of new holes for the crossmember, but I'm not sure.
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
