Tranny problems
Old Dec 18, 2001 | 04:28 PM
Trent257's Avatar
Tranny problems
when it shifts from 1st to second, it jerks REAL bad, should i get th fluid replaced, about how much does that cost?
Old Dec 18, 2001 | 06:02 PM
transfixleo's Avatar
Are your shift points still at the normal time or are they now late? If they are normal then you could have a broken 1-2 accumulator spring. This can be replaced at the same time as a fluid and filter and would cost under $100 to have done. If the shifts are also late then you probably have a sticky throttle valve in the VB. I would suggest a TransGo Shift Kit to permanently fix this.
greenyone
Sep 2, 2015 03:39 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
masonta
Sep 1, 2015 06:40 PM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:52 PM
