what is the BEST way to get ALL the freaking tranny fluid out? TRANSFIXLEO!!!
ok, i have heard so many ways to change the most tranny fluid as possible.
#1) Disconnect the cooler line going TO the radiator, and place it in a bucket, Then either put the return line in a clean bucket of tranny fluid, OR pour fluid in the tranny manualy as you RUN the engine.
#2) Drop the pan, take off the inspection cover and there should be a drain plug that u can disconnect to get most of the fluid out. But now i hear there IS NO drain plug.
#3) Change the fluid, and put a drain plug in the pan. Drive for a day or two, then drain the fluid gain, drive the car a few more days, drain the fluid again. Even though this will mix all the fluid... (there are other slight variations on this.)
HOW DO ALL THE PROFESSIONALS DO THIS?
Car: 82 camaro SC
Why do you want to get all the fluid out? I would say the best is to remove the tranny from the car and pull the converter. Then tip the tranny(tailshaft down) and drain a bunch out. When I had mine out and did this, the refill took a little more than a case. You might also find someplace that hooks to the both cooler lines and does a flush. If you pull just one line and drain it you risk running the pump dry.
I like to use a pressure gauge to first see how it is operating and then I take the head off of the gauge and put it in a bucket and start the car. I have done this along with adding oil to the tranny and watch until it looks fresh. This takes a fair amount of oil though. Remember to then drop the pan and change the filter. You can do essentially the same thing by doing it with the cooler line and a rubber hose going into a bucket.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
HoosierinWA
Oct 7, 2015 10:15 AM
