B&M megashifter intermittent no start
Old Sep 19, 2015 | 08:53 PM
PeteK825's Avatar
Engine: sbc 355, Lunati cam (lost cam card)
Transmission: Stock 700r4
Axle/Gears: 3.73 posi
Installed a mega shifter about month ago, worked flawlessly for 2.5 weeks went to start no start then after a couple expletives it started worked for another day then wouldn't start at all. Checked everything for the shifter after putting the two wires together for the neutral safety switch it started fine. Figure it's the safety switch took and switched the 2 switches again would start right up with new switch installed only lasted 2 days. My question is has anyone experienced both switches going bad or any suggestions?
Old Sep 20, 2015 | 12:53 AM
Night rider327's Avatar
Car: 1988 Camaro
Re: B&M megashifter intermittent no start
My micro switches from when I bought the shifter 17 years ago are both still working perfect.
Make sure the switches are bad before tossing or replacing. Use a volt/ohm meter to check them.
The little lever arms can bend and not touch the little bumps on side of shift gate plate. Also the switch mounting is adjustable.
Not sure if they have changed the shifter design in the last 17 years or not but mine was setup where you put the NSS and back up light switches on top of each other, put 2 long skinny bolts through the 2 switches and through the mounting spot on shifter. The switches then can be moved around some due to holes being oversized so you can adjust as needed. If your screws are not tight enough or if your alittle out of adjustment the switch arm will not hit the bumps on the plate enough to trip the switches action.
Old Sep 22, 2015 | 10:21 AM
roysatikas's Avatar
Car: 91 RS
Engine: 4 bolt 350, .060 over
Transmission: 700R-4
May not be the shifter and just coincidental the problem is happening now. I had that intermittent start prob on my '91 awhile back. The starter enable relay was going bad and it drove me nuts, same thing you describe, mess with something electrical and it starts, I was trouble shooting through the starter and its wires etc.
The relay is located behind the kick panel by your left foot
Old Sep 22, 2015 | 10:47 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
With intermittent problems like this you sometimes have to wait for it to fail and then use a multi-meter to find the problem. So bring one with when you drive it around.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
CORV3TT3
Aug 23, 2015 11:26 AM
92camaroJoe
Aug 13, 2015 06:07 AM
