Rebuilding TH700r4
Old Oct 5, 2015 | 12:12 PM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
Rebuilding TH700r4
I'd like to rebuild my 700 to stand about 300HP crank (305 TPI with mods).
First question is how to check which year is it: pre or post '87 ?
Second is where to buy and which kit to have all the parts to do full rebuild ?
I'm form Europe so i want to order all stuff to avoid waiting for any part.
Links would make easier to buy as my English is not that good.
Best regards
Old Oct 6, 2015 | 08:20 AM
Tony V's Avatar
Car: 88 Camaro
Engine: 383
Axle/Gears: Moser 9 inch/4.11 TruTrac
Re: Rebuilding TH700r4
http://www.novak-adapt.com/knowledge...matic/th700r4/
Old Oct 6, 2015 | 01:29 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Wow...amazing! I never knew there were so many parts/pieces in a transmission. A must watch for anybody....all 11 episodes.
Excellent videos!
Old Oct 12, 2015 | 02:27 PM
Pro Built Automatics's Avatar
The 1988 700R4's use the second design valve body. The Heavy Duty rebuild kit that I offer is the most complete kit out there. I use USPS Priority Mail to send it to Europe. Let me know if I can be of help.
Old Oct 12, 2015 | 04:16 PM
WASyL's Avatar
any web adress to make order ( or are You http://www.700r4l60e.com ? ), any price list, my trans has 9 which stands for 1982 and 1989, how to recognize which one it is ?
best regards
Old Oct 12, 2015 | 04:42 PM
If the number on the passenger side of the transmission starts with a 9 it is a 1989. The input shaft will measure .990" +/- .005" in diameter. With the pan off it will have a tube that goes front the front pump all the way to the back to the auxiliary valve body. A 1982 will have no tube and the input shaft will measure .890" +/- .005" in diameter. To order, go to: 700r4l60e.com or (best) call me at 909 795-1876 PST anytime in the afternoon or evening, except Thursday evening. You are "from" Europe, not "form"....
MSRed91Camaro
Oct 6, 2015 01:56 PM
1990FirebirdGTA
Sep 22, 2015 07:26 PM
apie2546
Sep 20, 2015 01:03 PM
Keiffer76
Sep 9, 2015 08:52 PM
