Hi, Iīm sure this has been asked before but I just COULDNīT find a solid answer for it, if I install a 3.73 rear end in a 92 Camaro 305 TBI, I know I need the gray and purple gears to correct the speedo, my question is, is there any diference in the gears between a cable speedo and a VSS or are they the same?
http://www.ebay.com/itm/43-tooth-700r4-TH350-TH400-GM-Speedometer-driven-gear-/151609357225?hash=item234c9f33a9&vxp=mtr#shpCntId
http://www.ebay.com/itm/15-tooth-700r4-TH350-GM-Speedometer-drive-gear-grey-8642620-/151667176916?hash=item23501175d4&vxp=mtr
Those are the ones Iīm looking to buy.
sofakingdom
close
- Join DateSep 2005
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- CarYes
- EngineUsually
- TransmissionSometimes
- Axle/GearsBehind me somewhere
- Liked:2,454 Times in 1,874 Posts
Drive gear is the same, driven is not.
Quote:
Thanks for clearing that up for me!Originally Posted by sofakingdom
Drive gear is the same, driven is not. Now, anyone have any idea where I could order them? Or is there any other way to fix the speedo?
jmd
close
- Join DateJul 2000
- LocationAridzona
- iTrader Feedback Score(4)
- Car`86 SS / `87 SS
- EngineL69 w/ TPI on top / 305 4bbl
- Transmission`95 T56 \ `88 200-4R
- Liked:93 Times in 90 Posts
http://www.transmissioncenter.net/sp...0gear%20driven
44 tooth is probably a better driven gear for 3.73 gears if you have stock height tires.
