Busted Torque Arm mount - jack up the car enough to work!
Old Oct 20, 2015 | 05:10 PM
Ragtop Man's Avatar
So, I found all the bits at gmpartsdirect.com, and a local nut/bolt place that just handed the fasteners to me N/C (!) Thanks Suburban!
Now, how the heck do you get a snakes-belly-low thirdgen up high enough in the air to actually work underneath it?
Rear end? No problem. Thanks axle. Front end? Big problem. Need a good place to put the jack that won't bend the s!#$% out of the structure.
Would a 2X8 on the jack pad spread the load enough under the front lcas to get some jackstands underneath it?
Thanks!
Old Oct 20, 2015 | 05:45 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Busted Torque Arm mount - jack up the car enough to work!
Drive up on some wood first and yes , the front LCAs are aValid lifting point.
Attached Thumbnails Busted Torque Arm mount - jack up the car enough to work!-cam01992.jpg   Busted Torque Arm mount - jack up the car enough to work!-cam01988.jpg
Old Oct 20, 2015 | 06:41 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
I usually jack up the rear of the car first and get the rear on jack stands.
Then I jack from the front sub-frame rails and when high enough put jack stands under the A-Arms.
I usually now use a block of 2x4 to protect the rails from the jack pad.
Old Oct 21, 2015 | 12:01 AM
Night rider327's Avatar
Car: 1988 Camaro
Shop floor jack under the K member, dead center... Jack it up and put stands under the A arms.. Or put 'oil change' ramps under the front tires after it's jacked up
Or drive up on those yellow metal or black plastic 'oil change' ramps in the front (use a 2x6 or 2x8 to lengthen the ramps enough to get up them with out dragging)
Rear... Shop floor jack under the center of rear axle housing, jack up and put stands under axle tubes or 'oil change' ramps under tires..
I have done the above at least a thousand times in the past 17 years
Old Oct 21, 2015 | 08:57 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
If I need to get all four corners up in the air, I start at the front.
Working on one side of the car, I approach the front of the car straight on with the floor jack between the tire and air deflector, putting the jack pad under one of the control arm spring pockets and lifting it high enough to put a screwed together stack of 1x12 pine boards under the tire. This is to get the front end high enough so the jack handle can swing during the next step.
I let the car down onto the boards and (still working from one side of the car) approach the center of the cross member diagonally from the lifted corner (between the tire and air deflector), putting the jack pad centered under the k-member and continue lifting.
I move the stack of boards and secure the car with stands under the control arm spring pockets.
db057
Jan 10, 2020 08:55 PM
Ed1LE
Sep 30, 2018 09:14 AM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
Kylej68
Sep 28, 2015 10:00 AM
the_hamturdler
Sep 22, 2015 02:59 AM
