12 bolt rear
Old Oct 21, 2015 | 11:18 AM
nixonomics's Avatar
Car: 1984 z28
Axle/Gears: 3.23 posi
12 bolt rear
Hey all, I just brought my first camaro. Now, it needs a rear end. The seller gave me a 10 bolt off of another 3rd Gen (3.23 posi) but one of my friends has a 12 bolt off of a 71 El Camino. I was in wondering how much work it would take to get the 12 bolt in, and if it would take a lot of fabrication.
Old Oct 21, 2015 | 08:04 PM
big gear head's Avatar
Re: 12 bolt rear
Huge amount of work and a lot of fab. You will also be destroying a good Chevelle 12 bolt. You can buy a bolt in 12 bolt housing from Moser, Mark Williams, Strange Engineering and probably some others.
Old Oct 21, 2015 | 09:51 PM
nixonomics's Avatar
Car: 1984 z28
Re: 12 bolt rear
If only I could afford those
It's a shame because it's cheap and available to me... oh well! sticking with the 10 bolt for now then!
Old Oct 21, 2015 | 10:41 PM
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Re: 12 bolt rear
Depending on the codes on the 12 bolt you might be able to flip it for a pretty penny to fund a stronger rear for the Camaro.
Old Oct 21, 2015 | 10:43 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 12 bolt rear
Cheap doesn't mean you can use it. The third gens torque arm suspension prevents you from installing a diff not designed for the car. Same goes for any other junkyard diff other than from a third or fourth gen.
By the time you fabricate and install some way to attach the torque arm, you'll probably have spent enough to buy a bolt in diff.
The El Camino diff is also probably too wide so add in the cost of narrowing, new axles etc.
The most inexpensive diff you can do is a 9". You can buy a bolt in housing with axles for less than $1500. It's designed to use your current brakes. Supply a junkyard center section and away you go.
The cheapest way to go is to bolt in another 10 bolt diff from a third gen. If you make enough power to break it, then decide if a 9" or 12 bolt is still too expensive. If you plan on making enough power to break a 10 bolt, you should be starting at the back and moving forward. When that's all done, the last thing you need to invest in is the engine.
Old Oct 22, 2015 | 08:03 AM
nixonomics's Avatar
Car: 1984 z28
Re: 12 bolt rear
Yup!! I have a 10 bolt now so I'm going to go ahead and slap that one in. But the 9" ford seems possible in the near future... cheaper than what I was seeing for aftermarket 12 bolts!! It's easier to rationalize $1500 + some for gears than $2000+ for an aftermarket 12 bolt (or a whole lot a fab and ruining a 12 bolt).
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
NAWTDADZ
Feb 28, 2016 12:37 AM
knightinblackar
Brakes
Oct 13, 2015 05:26 PM
NAWTDADZ
Oct 8, 2015 03:07 PM
84-Z28-Canada
Oct 7, 2015 03:24 PM
