Wiring plug ID if possible
Old Oct 22, 2015 | 10:56 AM
Gambit TA's Avatar
Car: 1982 Trans-Am Stroker 388
Engine: Chevy 350 four bolt Stroker 383+60
Transmission: Tremec T56 6 Speed
Axle/Gears: 4.56-1 posi
Hello Guy's I have just rewired all the charging and starter wiring and some of the older looking wiring, just to be sure the Old girl will keep going as she should. How ever I have a plug that I didn't tag or the tag came off ? Can you Guy's help me out and let me know what it is for and where it go's or should go ? PLEASE
wiring plug that has no home and I can't find one for it ? Could it be the old trans starter plug ?
Old Oct 22, 2015 | 11:01 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Wiring plug ID if possible
what vicinity is that in? Color wires??
Old Oct 23, 2015 | 03:32 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Weatherpak 2 x 2 is a TCC wiring connector, at least on 700-R4.
I believe the TH200-C in 1982 used the same connector.
Old Oct 25, 2015 | 11:43 AM
Gambit TA's Avatar
It is in the trans tunnel and the wire's are Brown and Red.
Old Oct 25, 2015 | 11:44 AM
Gambit TA's Avatar
It is a 1982 200-C or it was anyhow. what is a TCC wiring connector for ?
Old Oct 25, 2015 | 11:50 AM
Gambit TA's Avatar
This is another pic of the same plug.
Old Oct 25, 2015 | 12:20 PM
jmd's Avatar
jmd
The wiring allows the ecm to monitor pressure switches and control torque converter lockup.
Old Oct 26, 2015 | 11:00 AM
Gambit TA's Avatar
Thank you for that, I don't have any of that any more. So could you tell me where I may find the trans Start inhibitor switch wiring or what colour they are ?. I have NO crank off the key and the starter trigger wire is dead on the meter too many Thanks Paul.
Old Oct 26, 2015 | 12:33 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
My guess is that the switch assembly was mounted to the shifter mount framework. This switch also provides for backup lights and a P/N input to the ECM. As for the P/N input, leave it open for always in drive.
Look for two heavy gauge purple wires in the console area for the P/N safety switch connector.
RBob.
Old Oct 28, 2015 | 01:05 PM
Gambit TA's Avatar
RBob.
Thank you RBob, I have a Big Purple wire that was going to a black plug that also has a Big Yellow wire and smaller blue wire,green wire,orange/black trace and black/white trace wire too. Could you tell me what they are all for ?. I thought that the Green wire and Blue wire was the back up lights but I am not 100% sure on any of them . if you can help it would be great, as I would really like to get the old girl running by snow fall hehe Thanks PAUL
83DaytonaTA_Ian
Apr 2, 2022 09:17 PM
TonysBird
Nov 28, 2015 10:00 AM
transamaster
Nov 13, 2015 03:34 PM
FortKnox
Exterior Parts Wanted
Oct 19, 2015 11:53 AM
Cleotiz
Oct 18, 2015 12:14 PM
